In the graph below, I´d like to (i do need to) replace the ‘Views’ node by a code block or Python script. The reason is that it can change itself when the user creates or deletes some view.
That Python script in the graph reads the Schedule (I didn´t find the author or post now and don´t remember, unfurtunately) - and i will merge about 10schedules.
Any idea about a way replace it? Maybe inside the python code?
import sys
clr.AddReference("RevitAPI")
elements = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Views).WhereElementIsNotElementType().ToElements()
def filter_list(elements, search_str):
"""Given a list of Views, returns only those which
contain a given string in their name"""
passed = []
for element in elements:
name = element.Name
if search_str in name:
passed.append(element)
return passed
NameSrch = IN[0]
FoundViews = filter_list(elements, NameSrch)
OUT = FoundViews
