How to avoid code block
how to avoid the above code block
clr.AddReference(‘RevitNodes’)
clr.AddReference(‘RevitAPI’)
from Autodesk.Revit.DB.Mechanical import *
a =
fname = FilteredElementCollector(doc).OfClass(ViewFamilyType).ToElements()
OUT = fname
or what you mean is output the name from python code?
@shibujoseukken Look at api docs:
http://www.revitapidocs.com/2018/e372092e-ff47-71c2-1272-50ab08e5a41d.htm
Hi @shibujoseukken,
Is that what you’re expecting ?
clr.AddReference('RevitAPI')
names=[]
views = FilteredElementCollector(doc).OfClass(ViewFamilyType).ToElements()
for view in views :
	names.append(view.FamilyName)
OUT = views, names
http://www.revitapidocs.com/2018/10de5c66-1b4b-9214-4036-27a6b24e5703.htm
@shibujoseukken, please refrain from duplicate posts.
