How do l manage my lists, such that l can process or run a list by its vector?
I am using the rebar by curve node and using the curve with overlap node, wish to not only generate rebar which has been split to criteria, but with a side offset as the node allows, yet the issue is in one direction the offset is correct and in the other direction it is not.
Any thoughts would be appreciated.
