Hi @viktornrozalite ,
the code block is used to put the last item back at the top of the list, this can be done in the python code
import sys
import re
import System
clr.AddReference('RevitAPI')
toList = lambda x : x if hasattr(x, '__iter__') else [x]
inputView = UnwrapElement(IN[0])
lstfilterName = [doc.GetElement(xid).Name for xid in inputView.GetOrderedFilters()]
lstfilterName.insert(0, lstfilterName.pop())
OUT = lstfilterName
