Shortest path with dynamo
Hi I’m trying to create a workflow to calculate de shortest path for waste collection on a building, but I’m struggling. The idea is to do something similar to a reverse delivery workflow (ie going from point to point of collection until transport capacity is reached then move to discharge point. Has anyone seen a similar workflow that can be shared or could give me some tips? Thanks in advance!!
You will find some info if you look for egress route like this
There are some more ideas about shortest paths and some good discussion here.
this is a deceptively complex math/geometry task.
If you google ‘Travelling salesman problem’ (as mentioned in the post link from Ewan) you will see what I mean.
Not the right answer for a Dynamo forum, but I have done something similar using QGIS (free/opensource)- which has algorithms specifically for working out nearest neighbours or shortest path. It is actually quite easy- just need some CAD lines, as shown in the example below.
You basically simplify using line to lines represent possible paths- and can calculate a distance matrix between points on the network, or a shortest path between points
There are some packages for Dynamo to use this information
