Hi, I am unionizing each beam with its intersecting elements. Some were successful but some failed. I captured the errors as follows. Anyone knows where are the problems and how to fix it? Thanks!
"System.ApplicationException: Unable union two Solids : BODY_VERTEX_CRUMBLE -- coincident face_face_ints with different body vertices
at Autodesk.LibG.Solid.csg_union(Solid other)
at Autodesk.LibG.SolidHost.Union(ISolidEntity geometry)
at Autodesk.DesignScript.Geometry.Solid.Union(Solid solid)"
"System.ApplicationException: Unable union two Solids : INCONS_VERT_ATT -- inconsistent information in vertex and coedge attributes
"System.ApplicationException: Unable union two Solids : OUTSIDE_RANGE -- new ef_int outside edge
"System.ApplicationException: Unable union two Solids : FACE_BOUNDARY -- wire being deleted crosses face boundary
"System.ApplicationException: Unable union two Solids : EDGECOIN_PROBLEM -- system inconsistency processing edge coincidence
"System.ApplicationException: Unable union two Solids : INCONS_REL -- inconsistent edge-face relationships
The group in pink gets the intersected elements with each beam. I think it has no problems. The python script node is like this, which uses the try-except to capture the errors:
Here are the dynamo and model flies:
dynamo.dyn (38.3 KB)
