There is unlikely an easy fix. Boolean operations on solids fail at some point in most software. Usually co-planar faces (faces in the same place), or very tiny overlaps will cause errors. Could you upload or share a link to the smallest part of your project that still causes this issue? and the Dyn file too. Have you tried just with two elements to start with?
