Hi friends
I’m new using dynamo
I have a corridor that has as assembly a layer of pavement of 20 cm of thickness, how can I turn into solid that layer of pavement?
@joel.evange95 There is no dynamo node for creating solids for a corridor, but only a Corridor.GetSolids node to get the corridor solids by filtering property sets. To create the solids, you have to use the Export Corridor Solids command on the ribbon.
