Learning:
import System
clr.AddReference('RevitAPI')
clr.AddReference('System')
wall = UnwrapElement(IN[0])
bottomext = wall.get_Parameter(BuiltInParameter.WALL_BOTTOM_EXTENSION_DIST_PARAM).AsDouble()
topext = wall.get_Parameter(BuiltInParameter.WALL_TOP_EXTENSION_DIST_PARAM).AsDouble()
OUT = bottomext,topext
So i try to get Parameters(BuildIn) from my wall. Top/Basement Offset, it shows 0. in my testfile the wall has an offset.
How can snoop my BuildinParameters which Object Type they have f.e. is length, area and volums are all Double ? how do i navigate with the lookupTable? (in my example)
So have i to give “digits” ?
SeanP
May 20, 2022, 12:44am
2
BuiltInParameter is WALL_BASE_OFFSET and WALL_TOP_OFFSET I believe.
Also when you snoop, you can go into Parameter Set like you show, then there is a button I believe on the bottom left that says Enums something. This will give you the BIP associated.
@SeanP ,
do you know how to get to the metric system ?
offset it seems to it is in inches and foot
is there somthing like
doubleAsMeters ?
KR
Andreas
There is a node called “Convert Between Units”
@leonard.moelders i know but i got an error!
import System
bottomext = UnitUtils.ConvertFromInternalUnits(wall.get_Parameter((BuiltInParameter.WALL_TOP_OFFSET).AsDouble(), DisplayUnitType.DUT_MILLIMETERS)
topext = UnitUtils.ConvertFromInternalUnits(wall.get_Parameter(BuiltInParameter.WALL_BASE_OFFSET).AsDouble(), DisplayUnitType.DUT_MILLIMETERS)
you mean literal ConvertBetweenUnits i use ConvertFromInternalUnits but i got an syntex error
i started a new topic already
Do you need to do it in python? With the node it should work:
no, but i learn. I want useing the Revit API as enviroment. @leonard.moelders
Then try this:
Here is an example using Revit 2022, but the import should be the same.
OUT = UnitUtils.Convert(11.7,UnitTypeId.Feet,UnitTypeId.Millimeters)
Keep in mind too that in R2021 the DisplayUnitType was depreciated, and then in R2022 is it replaced by the SpecTypeId, ForgeTypeId and UnitTypeId classes.
you need to watch out for your revit version, it seems you’ve looked into an api-documentation for an older version as in Revit >=2022 there was a change.
To adress this problem you can use something like this to get your code working for older and newer versions of revit:
if int(DocumentManager.Instance.CurrentUIApplication.Application.VersionNumber) < 2021:
factor = UnitUtils.ConvertToInternalUnits(304.8,doc.GetUnits().GetFormatOptions(UnitType.UT_Length).DisplayUnits)
factor = UnitUtils.ConvertToInternalUnits(304.8,doc.GetUnits().GetFormatOptions(SpecTypeId.Length).GetUnitTypeId())
bottomext = wall.get_Parameter(BuiltInParameter.WALL_BASE_OFFSET).AsDouble()
convbott = UnitUtils.Convert(bottomext,UnitTypeId.Feet,UnitTypeId.Millimeters)
topext = wall.get_Parameter(BuiltInParameter.WALL_TOP_OFFSET).AsDouble()
convtop = UnitUtils.Convert(topext,UnitTypeId.Feet,UnitTypeId.Millimeters)
OUT = convbott, convtop
it works but i create 2 variables… @leonard.moelders is there a way to do it in one line?
what do you want in one line exactly?
just getting the offsets in my project units … later on i will do some QM issues
so walls have no offset , floors a.s.o. @leonard.moelders I want to learn navigate in the API inviroment.
You get your top und bottom offset as you want. So what is the problem here? Which part of your code do you want to be an one-liner?
is there a way to comprehense the code. So to store the unitsconverting and the value in the same variable ?
if it not is ok for me @leonard.moelders
You could use a def:
def UnitConverter(builtinparameteroffset, fromunit, tounit):
text = wall.get_Parameter(builtinparameteroffset).AsDouble()
conv = UnitUtils.Convert(text,fromunit,tounit)
return conv
builtinparameteroffset_list = [BuiltInParameter.WALL_BASE_OFFSET, BuiltInParameter.WALL_TOP_OFFSET]
fromunit = UnitTypeId.Feet
tounit = UnitTypeId.Millimeters
output = []
for item in builtinparameteroffset_list:
output.append(UnitConverter(item, fromunit, tounit))
OUT = output
But this is only shorter, if you do it several times
Or simply save some lines like this:
convbott = UnitUtils.Convert(wall.get_Parameter(BuiltInParameter.WALL_BASE_OFFSET).AsDouble(),UnitTypeId.Feet,UnitTypeId.Millimeters)
convtop = UnitUtils.Convert(wall.get_Parameter(BuiltInParameter.WALL_TOP_OFFSET).AsDouble(),UnitTypeId.Feet,UnitTypeId.Millimeters)
@leonard.moelders yes, i got from @Elie.Trad the same conclution! Many thanks …
I want to get my offsets in metric system f.e. mm
import System
import Revi…
And if you ever have problems with the api:
Use this page: ApiDocs.co
There you can find examples for that use what you are looking for, e.g. for your case:
