Slabs, point driven or slanted, how to get the difference?
# 0️⃣ Get slanted slab
slabs = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Floors).WhereElementIsNotElementType().ToElements()
# Thickness from slab parameter
thickness_slab = [
    round(UnitUtils.Convert(
        i.get_Parameter(BuiltInParameter.FLOOR_ATTR_THICKNESS_PARAM).AsDouble(),
        UnitTypeId.Feet,
        UnitTypeId.Centimeters
    )) for i in slabs
# 1️⃣ Thickness from bounding box
thickness_Box = []
# 2️⃣ Bounding Box
get_slanted_slabs = []
for idx, e in enumerate(slabs):
    bb = e.get_BoundingBox(None)
    if bb:  # Ensure the bounding box is not None
        delta = bb.Max.Z - bb.Min.Z
        unitMetric = round(UnitUtils.Convert(delta, UnitTypeId.Feet, UnitTypeId.Centimeters))
        thickness_Box.append(unitMetric)
        # Compare bounding box thickness with parameter thickness
        if abs(thickness_slab[idx] - unitMetric) > 0.1:  # Use a small tolerance
            get_slanted_slabs.append(e)
# ✅ Output results
OUT = [s.Name for s in get_slanted_slabs]
My code works pretty well do get all slanted floors, but how can i check if they are point driven or slanted modeled ?
Try getting the slab shape editor and see if it is enabled.
Also, check if a situation where both slave shape edits and the slope arrow exists. If so you’ll also have to get the sketch and see if it has any lines defining slope.
@jacob.small
background is that the model style has impact on the geometry. Revit generates the volume with math, BUT rip iTwo extracts it from the “true” geometry"
SlabShapeEditor Class
A solution by analyzing the type of faces (PlanarFace or other)
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
def is_driven(elem):
    global opt
    faces = []
    elem_geos = elem.get_Geometry(opt)
    if elem_geos is not None:
        for geo in elem_geos:
            if isinstance(geo, DB.Solid):
                for face in geo.Faces:
                    faces.append(face)
    elem_geos.Dispose()
    return not all(isinstance(f, DB.PlanarFace) for f in faces) if faces else False
def toList(x):
    if isinstance(x, (list, dict)) or \
            (hasattr(x, "GetType") and x.GetType().GetInterface("ICollection") is not None):
        return x
    else : return [x]
opt = Options()
lstelems = toList(UnwrapElement(IN[0]))
OUT = [is_driven(e) for e in lstelems]
@c.poupin
meanwhile i made this in pyRevit. It is more user friendly…
# -*- coding: utf-8 -*-
__title__ = "Slanted"
__doc__ = """Date    = 29.12.2022
_____________________________________________________________________
Description:
Toggle visibility of room categories (Color Fill and Interior Fill) in the active view.
Author: """
# IMPORTS
from Autodesk.Revit.DB.Architecture import Room
#pyrevit
from pyrevit import forms, script
# .NET Imports
clr.AddReference("System")
# VARIABLES
uidoc = __revit__.ActiveUIDocument
doc   = uidoc.Document
view  = doc.ActiveView
# 🎯 get Linkify Function
output = script.get_output()
linkify = output.linkify
slab_name = [i.Name for i in slabs]
thickness_slab = [
        UnitTypeId.Feet,
    )) for i in slabs
#  Thickness from bounding box
thickness_Box = []
# 🔀 order model style of slabs
get_default_slabs = []
#  Bounding Box
        if abs(thickness_slab[idx] - unitMetric) > 0.1:  # Use a small tolerance (chatGPT)
            get_default_slabs.append(e)
slanted_type = []
#  get point driven slabs
for slanted in get_slanted_slabs:
    ss_editor = slanted.SlabShapeEditor
    if hasattr(ss_editor, "IsEnabled"):
        slanted_type.append("point driven")
        slanted_type.append("direction driven")
slab_id = []
# get slanted elements actively
for s in slabs:
    linkify_slanted_slabs = linkify(s.Id, "{}".format(str(s.Id)))
    slab_id.append(linkify_slanted_slabs)
# Transpose the table data to list each element vertically
table_data = list(zip(slab_id, slab_name, slanted_type + ["N/A"] * (len(slab_id) - len(slanted_type)), thickness_slab))
#  Output results in a table
output.print_table(
    table_data=table_data,
    title="Slabs Check",
    columns=["Id", "Type", "Shape Type", "Thickness (cm)"],
    formats=['', '', '', '{}'],
