Simple schedule replace on sheets
Looking for some help on schedule replacing script.
I want the logic to be like this:
  1. Look if a schedule called R1 (string input) is present on a sheet
  2. Delete schedule R1 from sheet (not delete it completely from project)
  3. Add schedule R2 (string input) (this schedule is already created)
First you have to collect all the schedules in the project.
Use Category.ByName and All Elements of Category.
Or you could start by getting all sheets…
Use the nodes mentioned.
After some bool masks I have target sheet, and both involved schedules
Now I need something to delete the -001 schedule and place down -002 one
Use this code to get the location of the original schedule view. Then delete the original schedule and use the Viewport.Create node from rhythm to add the new schedule to the sheet.
schedules = UnwrapElement(IN[0])
result = []
for schedule in schedules:
	loc = schedule.Point
	result.append(Point.ByCoordinates(loc.X,loc.Y,loc.Z))
OUT = result
Hello, here is a possibility of deleting ScheduleonSheet
Cordially
christian.stan
The node tree is working, there is one issue with python though.
Hello, rental with nodes
cordially
christian.stan
That is perfect, thank you very much!
