Simple Model Lines won't behave... me thinks :)
I have a series of points join to create lines using Line.ByStartPointEndPoint, they appear just fine in the Dynamo view (but not in Revit). When I attach them to the ModelCurve.ByCruve… I get no lines in Revit. I was just hoping to draw those lines.
Any help is, once again, more then appreciated :slight_smile:
Seems to work for me
Stop bragging Vikram, :slight_smile: just won’t work for me.
Hi Daniel,
Can you show us your workflow so that we can know your issue.
:slight_smile: Did you try looking in an elevation, I couldn’t spot it in a 3D view.
Also check if the line lengths are large enough wrt the units in the Revit project
Ok, feel free to punch me in the face but… I restarted Dynamo and now i get the damn lines :slight_smile:
I owe you a beer now
Please, ModelCurve.Bycurve node exist at which package?
It comes default with Dynamo (out-of-the-box). Have you checked your built in library?
which package?, I searched on it, and what is the out-of-the-box?
Not a package. Open up Dynamo, go to the search bar, and type ModelCurve.ByCurve and it should show up. Out-of-the-box means it comes standard with Dynamo, not in a package.
Thank you very much, I found it, I appreciate your helping.
