Morning,
so i have that simple if that wont return the true value… any idea?
It’s because the "False " input is an empty list at the moment. I know that it is a strange behaviour. I actually noticed it this morning in another case.
Try ScopeIf instead, Some packages also have better working IF nodes.
I noticed that when i tested with simple string.
I can recommend the “ScopeIf+” package from Clockwork
Can you show a little more of your work-flow?
(preferably with previews enabled)
Use longest lacing on the scopeif+
The reason is that the “object.Isnull” returns x number of true/false values for each object in your list
scope if is a tricky node, the two branches must be totally independent, but it is very useful - it actually will not execute the branch that is not passed through. This is unlike all other nodes in Dynamo, it’s valuable when your branches have side effects like interacting with revit.
mmm… interesting.
I’ve been using Clockwork’s passtrough, ScopeIf sounds pretty much the same to me no?
