While i’m importing parameter value through Get parameter value by name in Empty place (null value) in object type it shows as system string and While searching in string .contains i have given search for null values but its showing as false means that (no null value in list ) but a null value is there in list what is the solution for this…
Hello @santhos.k and welcome to the forum
maybe you have some whitespaces
@sovitek its worked, thank you so much
further how can i make a seperate list for this true and false value from this code block
List.FilterByBoolMask should do it
yeah its done now, thanks
I just want to clarify here that empty and null are not the same thing. What you really have is just an empty string. This is why the object type is a string and not a null.
