Yien
1
Hi group!
I have a simple function i want to achieve, but i think it missed something…
there is 2 floors i want to know if they intersect, so i use the GeometryDoesIntersect. the result is “true”
then im doing a simple GeometryIntersect so that would be a Solid.
the problem is, i cannot see the result in 3d?!
I’m new to this forum by the way, but will surely be proactive.
thank you
Yien
Kulkul
2
Hi yien,
Hit geom right below in dynamo and then right click zoom to fit. Hope it helps.
are you in a custom node?
Yien
5
what do you mean by custom node?
i 've installed many package…
Yien
6
strange here… i tried on another computer and it works!
it is a graphic card related issus?
Yien
7
there is.
all i wanted was to create a simple boolean between 2 topographic surface, to see if they clashed.
Yes there are some known issues with different graphics cards, try installing direct x 11 and make sure to update the drivers for your card.
