Intersect of solids give me a lines
How can i fix it?
How can i get solid?
hello,
Doesn’t your wall fit with the other already?
In this case the result is correct.
edit:
On the other hand, I don’t know how to activate the one from dynamo (is there a custom node) or you will have to write this in python code.
otherwise you can create a volume from a bb (if your wall edges are perpendicular to your average line)
and operate unlike solids.
Cordially
christian.stan
Hello…could solid difference node help
