Shout & listen pairs
I suspect the Dynamo developers get tired of either being compared to Grasshopper or being asked to do something GH does.
But I’ll ask the question anyway..
Having spent some time recently using GH2- I’m loving the shout & listen pairs.
It basically acts like a hidden wire- you have separate out (shout) & and in (listen) ends, but nothing physically connects them.
You wouldn’t want to overuse it since it would quickly become confusing, but can help clean up the spaghetti.
Any consideration of something like this in Dynamo ??
Interesting concepts, but I can see how it gets confusion.
Functionally, how does this differ from hidden wires?
I admit it’s quite subtle- you know that data is either going to, or coming from somewhere else. Rather than being completely hidden.
Perhaps my OCD coming into play- but I used to pin Dynamo wires to try & tidy things up- but it becomes difficult to manage
I’m referring to the ‘hide wire’ feature added around 2.12 or 2.13. Pinned or not you need not see the wire anymore if you don’t want to, but if you select the node you now have something to trace so you can know where it comes from.
Wire Controls
I was curious so i looked it up.
My understanding is you can ‘break a wire’ and it can act like a List.Create
I think it is pretty neat.
Hi @jacob.small
thanks- yes, I understand that- the issue for me at least is that the wire completely disappears in Dynamo (only appears if the node is selected)
It might be a quirk of how I think (there are a few)..
But it is a little like writing code (in a visual sense)
Say you declare a variable or have a function- that might get used miles away in terms of lines of code- the only thing that joins them is the name- not proximity
So rather than spaghetti than joins the left to the right- you know that blue goes to blue and green to green. These nodes could be opposite ends of the graph, rather than having wires that traverse across everything that happens in between
yes,
I think you’d probably compose your graph with wires as normal, then split them and rearrange
I have a lot of those myself, which is why the forum is so helpful. :slight_smile:
My concern with this (and why personally I’d just hide the wire, using a intermediate code block if I wanted a name to track stuff by, is that there isn’t an easy way to find where Data1 is shouted from. I see a LOT of script, code, and graphs which call Data1 quite effectively, but tracking back where it’s actually defined is a herculean effort. By allowing the exposure of the wire you can trace stuff back to the source without having to play Where’s Waldo. I suppose a UI could layer on top of this, but that seems like a duplication of the other feature to me.
If you use Groups (like in @Andrew_Hannell screenshot) tracking back isn’t that much of an effort in my opinion. Tracking back the ‘spaghetti’ isn’t always easy either.
Also you don’t have to use it.
Anyways, i think things like the shout & listen, hiding wires, straight wires etc. are a personal preference.
Spring nodes has this as a feature.
I wasn’t aware of this- I’ll try it out
Many thanks @john_pierson
