when my dynamo open if i press any key to use shortcut like delete node or any shortcut this order do not work
if any one solve this problem i will by big thank for him
Assuming you’re in Dynamo for Revit, check to ensure your Revit build is fully patched, as I believe that there was a build which had a bug which resulted in this behavior.
