Sheets by Excel data
Hello everyone!
Practically everything I learned from Dynamo, was due to this forum, so I came to ask for help
I am looking to change some parameters of my Revit sheet using excel
I based my routine on some similar ones on the forum, but I’m stuck in a part that I can’t change.
The entry reads the spreadsheet and a text (which will be associated in column G of excel)
So when you type “ALI-TERR”, you must fill in the rest of the data on the sheet with what is on the line
My sheet takes data from a revit table.
the data in column A of excel, go to B of the Revit table
Excel “B” go to revit “C”
How do I get it to take the data only from this entry line and not from the entire spreadsheet, to complete my sheet?
Sheets.dyn (35.6 KB)
Hey,
I’m not sure I understand exactly… Are you looking to extract only data from column G and check whether the cell contains “ALI-TERR”?
How about ‘String Contains’ instead of ‘==’
Hope that helps,
Mark
@renanemeyer Try this: Sheets.dyn (36.6 KB)
:grinning: great! worked perfectly! thank you so much
do you know how to inform me how can i fill in the data for a certain column in the spreadsheet? like this?
I’m using element.setparamterbyname but the paramter name = the column name is not working
Shouldn’t you be setting the parameter of the Element? Not the Schedule?
If so, I would export the Element ID to your Excel as a column, and use that to Get the Element and Set the Parameter…
Hope that helps,
Mark
