Sheet Rename
I have a drawing with the following sheets and order:
GF, 1F, 2F, 3F, 4F & RF
I then want to rename them by prefixing a sequential number
as follows and separated by “_”
01, 02, 03, 04, 05 & 06
Expected output to read as:
01_GF, 02_1F, 03_2F, 04_3F, 05_4F & 06_RF
Please refer to image below
My problem is DocumentExtensions.GetLayouts is spitting
a sorted result.
Thus my result is 01_1F instead of 01_GF, etc.
Can someone help me with this please?
Thanks.
Regards,
Joel
Hi there,
The layouts probably get sorted based on when they were created. I haven’t worked with Civil3D files in combination with dynamo, so I can’t help you with how you should sort the layouts. However I would like to give you some advice. That node on the top isn’t very parametric, you could replace it with something like this:
This might also help: Dynamo Dictionary
So it seems like the problem is on the original node’s end since it is not ordering the data in the order of the sheets. Without changing that directly, I would look to use regex and vary my approach depending on how exactly your sheet format scales. Here is a solution for your specific example. Instead of simply appending to the “result” list variable in each step, it will probably be better to create a sublist for each type, sort each sublist, and then combine them all into the final result at the end. But this should get you started with python:
import re
#start with:
sheets = ['1F', '2F', '3F', '4F', 'GF', 'RF']
result = []
#reference only#
#final sheets should be:
final_sheets = ['GF', '1F', '2F', '3F', '4F', 'RF']
#so ordering of sheets should be this and then with numerical prefix
order = ['GF', 'F', 'RF']
#reference only#
#Identify sheets with the letters 'GF' and adds to result
#regex that looks for the string 'GF'
pattern = '(GF)'
for sheet in sheets:
    if re.search(pattern, sheet):
        result.append(sheet)
        pass
#Identify sheets with a number prefix and then 'F' letter and adds to result
#regex that looks for the string 'F' with a numeric prefix
pattern = '\d+[F]'
        pass
#Identify sheets with the letters 'RF' and adds to result
#regex that looks for the string 'RF'
pattern = '(RF)'
        pass
print(result)
Hi pieter.lamoen,
Thanks for your help. Although i don’t fully understand this but it does the work.
Regards,
Joel
It is shorthand for if-then-else.
l==1 ? “0”+s : s;
if l==1 then “0”+s else s
This means:
if l is equal to 1 (l is the calculated length of the string) then return the string with a prefix zero, else return the string as it is.
It appears that there isn’t a clear way to extract the layouts in the same order as they appear in Civil 3D. I spent some time finding and extracting the paperspace block items that represent the layouts, but they sort alphabetically too. I then took a look at the paperspace block parameters, but didn’t see anything that indicated a position relative to the other blocks/layouts. All that to say, I think we’re only going to get layouts sorted alphabetically…but I’m still a novice, so I could be wrong.
Nothing is sorted in AutoCAD, everything is done in the UI there.
Layouts have a taborder property so it is possible to sort, but you need to get the Layout object, not the blockreference.
Edit: there is no taborder node in the Civil3DToolkit, you might do something in Python or wait a while. Soon I will release a package with new nodes, with these it is possible to get the layouts sorted by taborder:
As they are in Civil 3D:
Thanks for the clarification. Really appreciate it.
Thanks for the time. Really appreciate it.
Thanks for the time. I’m still novice. Hope i could learn Python too.
Anton, the true hero! Super excited for your package release!
There’s a bunch of new nodes in Camber v3.0.0 that should help with this.
This looks promising… i will have a look later.
Thank you so much for the help…very much appreciated.
Hi mzjensen,
I finished installing Camber v3.0.0 but i could not access these Layout nodes as shown on your screen shot. Is it because of my C3D version?
Thanks ahead.
Regards,
Joel
Yes - you will need to upgrade to a later version of Civil 3D, as per the compatibility note in the release notes here: Releases · mzjensen/Camber · GitHub.
FWIW I would jump straight to 2022.1.1 if you can; no valid reason not to really.
