I’ve seen a few posts about this issue but have not found a solution. I have made a script to create plan sheets using the Sheet.ByNameNumberTitleBlockAndViews to create sheets one at a time. I am working on now combining a few other scripts into one script modified from my original to create all the Area Plan Sheets for One Level at a time. When I run this I get the warning that “View could not be packed on the sheet. The sheet size is 3 x 2 and the view to be added is 1.66… x 1.54…”. So by those numbers the view is smaller than the sheet, and the script works perfectly fine when doing the same views in the sheet by sheet script.
Also. there are scope boxes I have applied to the views and I have annotative crop turned off.
Okay so I was able to find the solution to my problem. I had saw in a few posts about using the Sheet.ByNameNumberTItleblockAndViews vs. Sheet.ByNameNumberTItleblockAndsView and I thought I had checked that but I did not. That seemed to help some. This script is creating Area Plan Sheets for specific floors. So in the script I am having dynamo duplicate a selected view a certain number of times and apply scope boxes to those views. If the original view that is getting duplicated does not have a scope box applied to it I still get the warning. So I am guessing on the dynamo side it is somehow seeing the original view as the extents or something, is the only thing I can figure. So I am working on updating the script to temporarily apply a scope box, duplicate the views, then remove scope box from original view.
