Sharing what I learned: Getting and Setting CANNOSCALE (Python w/ CAD .NET API)
Hi
I’ve been trying to change the current annotation scale in modelspace, using a python node in Dynamo. Took me a while to figure out this nuance. So, I wanted to share it.
Three examples below. To actually change the CANNOSCALE, you need to access the System Variable, not just the Cannoscale object property. Seems obvious in hindsight.
Cheers
Hello!
Is it possible to explain how to have this work for newbies that begins with Dynamo and Python?
Thank you
https://help.autodesk.com/view/OARX/2022/ENU/?guid=OARX-ManagedRefGuide-Autodesk_AutoCAD_DatabaseServices_Database_Cannoscale
Looking at
@hosneyalaa any idea how to get annotation scale of Mtext or Dimension object by its handle ID?
@Gauzdx
Can you see this
