Shared Parameter Export
Hey All,
I can’t quite work it out…
I woud like to be able to generate most of a shared parameter file from a project.
I can obviously export each one, one by one, which would potentially take a while.
I can also read info from an existing shared parameter file, but this is when you don’t have it.
It would be quite neat to export them all in a Dynamo hit, but I can’t quite seem to get all the required information…
Here’s where I got to… It seems that getting the info in the headings is locked away somewhere?
Any help appreciated :slight_smile:
Mark
SharedParameterExport.dyn (11.7 KB)
Hi Mark,
Is this what you’re looking for ?
Thanks Alban,
As long as that is not reading a Shared Parameter File, it’s just what I’m after, unfortunately I’ve just logged off :smile: I’ll have a look in the morning…
Thanks again,
Mark
Yes it’s all the shared parameters of the project and I also believe in families.
