Shaft BoundaryCurves
Hi all,
i’m trying to retrieve the geometry / boundarycurves of shafts.
The geometry seems to be empty, i assum this is a consequents of them being void types?
In the revit api there is the ShaftOpening.BoundaryCurves wich works in pyrevit for me to retrieve the boundarie curves. But it fails in Dynamo any ideas on what i’m doing wrong here, because i don’t really see it at this point :slight_smile: .
Thx for the help!
error given on the node:
Warning: NameError : name 'shaft_cruves' is not defined [' File "<string>", line 18, in <module>\n']
below my code and some screen shots:
Load the Python Standard and DesignScript Libraries
import sys
clr.AddReference("RevitAPI")
link = IN[0]
shafts = FilteredElementCollector(link).OfCategory(BuiltInCategory.OST_ShaftOpening).ToElements()
# Place your code below this line
shaft_curves =[]
for shaft in shafts:
    shaft_curves.append(shaft.BoundaryCurves)
OUT = shaft_cruves
Check the spelling of the final line - shaft_curves != shaft_cruves
thx @jacob.small,
my disclecatie wasn’t helping me out there :wink:
hi @jacob.small ,
i’m trying to use the retrieved line to create new shaft of lines from them.
I’m no expert at this but i’m not managing to convert the autodesk.revit.DB.curve(line) to a Autodesk.DesignScript.Geometry.Curve.
Is it possible at all to convert these?
what i’m also finding strange is that it seems to retrieve a lot of lines for some shaft, while they are rectangual in the model itself. any ideas on why this is?
i also found this code from the spings elementsketch node.
But this one only works on the shaft in the current model not the linked one:
#Copyright(c) 2016, Dimitar Venkov
# @5devene, dimitar.ven@gmail.com
import math
def tolist(obj1):
	if hasattr(obj1,"__iter__"): return obj1
	else: return [obj1]
elements = UnwrapElement(tolist(IN[0]))
getModel = IN[1]
accepted_mc = "Autodesk.Revit.DB.ModelLine, Autodesk.Revit.DB.ModelArc, Autodesk.Revit.DB.ModelEllipse, Autodesk.Revit.DB.ModelHermiteSpline, Autodesk.Revit.DB.ModelNurbSpline"
def almost_eq(line, mc):
	line2 = mc.Location.Curve
	xyz1 = line.Evaluate(0.5, True)
	if not line2.IsBound:
		xyz2 = line2.Center
		try: xyz1 = line.Center
		except: pass
		xyz2 = line2.Evaluate(0.5, True)
	if xyz1.DistanceTo(xyz2) <= 0.0001:
		return True
		return False
def clean1(l1):
	for i in xrange(len(l1) ):
		l1[i] = [x for x in l1[i] if x != None]
	return l1
def getSketch(el1):
	try:
		sk1 = doc.GetElement(ElementId(el1.Id.IntegerValue - 1) )
	except:
		sk1 = None
	if not getModel and sk1 is not None and sk1.GetType().ToString() == 'Autodesk.Revit.DB.Sketch':
		profile = sk1.Profile
		t1 = SubTransaction(doc)
		t1.Start()
		deleted = doc.Delete(el1.Id)
		t1.RollBack()
		profile, mc = CurveArrArray(), []
		for d in deleted:
			test_el = doc.GetElement(d)
			el_type = test_el.GetType().ToString()
			if el_type == "Autodesk.Revit.DB.Sketch":
				profile = test_el.Profile
				if not getModel:
					break
			elif getModel and el_type in accepted_mc :
				mc.append(test_el)
	ordered_mc = [ [None] * i.Size for i in profile] if getModel else []
	curves = [ [None] * i.Size for i in profile]
	for i in xrange(profile.Size):
		for j in xrange(profile[i].Size):
			curves[i][j] = profile[i][j].ToProtoType()
			if getModel:
				for k in xrange(len(mc)):
					if almost_eq(profile[i][j], mc[k]):
						ordered_mc[i][j] = mc[k].ToDSType(True)
						del mc[k]
						break
	return curves, clean1(ordered_mc)
result = map(getSketch, elements)
OUT = [r[0] for r in result], [r[1] for r in result]
Convert the Revit curves to Dynamo curves using the .ToProtoType() method.
Thx at @jacob.small for the help.
i figured the code out and now i have clear contours of the shaft.
I not only need to use the .ToProtoType() methode, wich was purely for dynamo.
I was also on the wrong path whit using the shaftopening.BoundaryCurves methode.
it seems that using this methode i get both the boundarycurves and the symbolic lines from the shaft.
And the later we really don’t needed ofc.
So for those people looking for the solution to retrieve clean shaft countours from shaft linked or in current model ( depending on wich doc u input into the node):
Dynamo / python:
import sys
link = IN[0]
shaft_curves =[]
    sketch = link.GetElement(shaft.SketchId)
    profile = sketch.Profile
    curves = []
    for profile_curve in profile:
        for curve in profile_curve:
            curves.append(curve.ToProtoType())
    shaft_curves.append(curves)
OUT = shaft_curves
