Setting pipe network data source in profile
Hi All
I have created a script that will create a profile view and add selected parts to it.
The only problem I have now is that the Data source containing the selected pipes does not get correctly selected when the profile view gets created. So I want to write a python code to set the pipe source.
Pipe data source selection
I found some code here - https://forums.autodesk.com/t5/civil-3d-customization/profile-view-bands/td-p/4744655
also referenced in another post about setting profile source info - https://forum.dynamobim.com/t/set-profileview-band-profile-1-or-profile-2-to-new-profile/55677/9
I have attempted to edit the code to set the pipe source, but I am quite new at the python node and get the error - unexpected token … I think the error is at line55, but I am not sure how to fix it - any help will be appreciated.
See the python code:
I also attach the script
Create profile view_styles defined.dyn (67.3 KB)
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
dataEnteringNode = IN
editor = adoc.Editor
civdoc =CivilApplication.ActiveDocument
def Set_pipesource(pv,pipesource)
	global adoc
	with adoc.LockDocument():
    	with adoc.Database as db:
        	#get profile view id
        	pvId =[0].InternalObjectId
        	#Open profile view
        	pvo = pvId.GetObject(OpenMode.ForWrite)
        	#get band set on profile view
        	pvbs = pvo.Bands
        	#get band item properties
        	pvbsi = pvbs.GetBottomBandItems()
        	#count number of bands
        	pvbsc = pvbsi.count
        	pvbscc = pvbsc-1
        	#loop through bands, check if pipenetwork type and set datasource
        	for k in range(0,pvbscc):
        		pvbsii =pvbsi.Item[k]
        		If pvbsii.BandType == BandType.Pipenetwork:
        			pvbsii.DataSourceId = [1]
        	return pvbsi
pv = IN[0]
pipesource =IN[1]
OUT = Set_pipesource(pv,pipesource)
Hi
Add line
t.Commit()
Thanks @hosneyalaa, I have added the t.commit() line and worked through some subsequent errors and renamed some variables. The script seems to run now, but the existing profile view does not get updated. I initally had the code wrapped in a function, but I would assume the OUT takes care of the output?
Any advice?
Create profile view_styles defined.dyn (69.7 KB)
# list of inputs
profview = IN[0]
pipe = IN[1]
global adoc
        # open a transaction
            # get the network id for the pipe
            pipe_id = pipe[0].InternalObjectId
            pipesource = pipe_id.NetworkId #[0] to use first item in "list"
            # get profile view id
            profviewId = profview.InternalObjectId
            # Open profile view
            profviewopen = profviewId.GetObject(OpenMode.ForWrite)
            # get band set on profile view
            profview_bandset = profviewopen.Bands
            # get band item properties
            profview_bandset_items = profview_bandset.GetBottomBandItems()
            # count number of bands
            profview_botband_count = profview_bandset_items.Count
            # loop through bands, check if pipenetwork type and set datasource
            for k in range(0, profview_botband_count - 1):
                active_band = profview_bandset_items.Item[k]
                # if statement gives error just set source, i.e. assuming all bands are pipenetwork bands
                # if active_band.BandType == BandType.Pipenetwork:
                # active_band.DataSourceId = pipesource
            t.Commit()
            # return profview_bandset_items - assuming the rCommit is a replacement for return
            pass
OUT = profview
Hi I’m sorry
My language bad
Read the subject you attached , in last subject
I think, you need this method
profview.Bands.SetBottomBandItems(bottomBands)
If not working
Can you attached example drawing
Hi @hosneyalaa - I appreciate your willingness to help. I have looked in more detail at this post: Re: Profile View Bands - Autodesk Community - Civil 3D and it seems like they create a collection of the band id’s , delete the bands, and then re-assign the “corrected” bands…
I have tried to mimic this approach, but I am not sure how to get the BandstyleId attribute.
        for m in range(profview_botband_count):
            band_id = profview_bandset_items[m].BandStyleId
            band_col.append(band_id)
gives me error: AttributeError: BandStyleId
Then I tried adding the inherent form ProfileViewBandSetItem.)
            band_id = ProfileViewBandSetItem[m].BandStyleId
gives me error: NameError: name ‘ProfileViewBandSetItem’ is not defined.
So… I am at the end of my rope…
I attach a sample drawing, code snippet and code.
Set PV band_test drawing.dwg (968.4 KB)
STW_Culverts_Create profile view.dyn (70.7 KB)
BandStyleId this property only set … check it
So you have any errors
Hi @hosneyalaa - Yes I get this error
hi
@hosneyalaa still no joy
import BandType Enumeration into code
https://help.autodesk.com/view/CIV3D/2022/ENU/?guid=0afb06b2-636c-7d6d-79ee-c06fb33ebb8e
Tried -
import Enumeration BandType
from Autodesk.Civil import BandType
:smiling_face_with_tear: - Sorry, I really don’t understand what I am doing wrong, I re-attach the drawing and script if that helps
Set PV band_test drawing.dwg (985.1 KB)
STW_Culverts_Create profile view.dyn (70.5 KB)
TRY
import sys
import traceback  # for debugging
civdoc = CivilApplication.ActiveDocument
# list of inputs
profview = IN[0]
pipe = IN[1]
output = []
global adoc
            pipe_id = pipe.InternalObjectId  # get pipe id from pipe object selected, [0] to use the first item in the "list"
            pipesource = pipe_id.NetworkId  # get the network id from the pipe
            profview_Id = profview.InternalObjectId  # get profile view id
            profview_open = profview_Id.GetObject(OpenMode.ForWrite)  # make the profile view editable
            profview_bandset = profview_open.Bands
            profview_bandset_items = profview_bandset.GetBottomBandItems()  # get band item properties
            profview_botband_count = profview_bandset_items.Count  # count the number of bands
            #profview_bandset_items.RemoveAll()  # bandstyleid saved in collection so can remove from profileview
            # loop through band collection, check if pipenetwork type and set datasource
            for band in profview_bandset_items:
                #output.append(band.BandType)
                if band.BandType == BandType.PipeNetwork:
                    output.append(pipesource)
            profview_bandset.SetBottomBandItems(profview_bandset_items)  # set bands in profile view
            t.Commit()
            #pass
OUT =  profview_bandset_items
STW_Culverts_Create profile view(1).dyn (70.9 KB)
Thank you so much for your patience!
