Inspired by @keith.sowinski (thanks for helping out on my previous thread). I managed to write my first python code to create profile view. But unfortunately hit the wall. Could someone please point me in right direction. Below is the code and error message:
#inspired by keith
# Add Assemblies for AutoCAD and Civil 3D APIs
clr.AddReference('acmgd')
clr.AddReference('acdbmgd')
clr.AddReference('accoremgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AeccPressurePipesMgd')
clr.AddReference('acdbmgdbrep')
clr.AddReference('System.Windows.Forms')
# Add standard Python references
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import os
import math
# Add references to manage arrays, collections and interact with the user
from System import *
from System.IO import *
from System.Collections.Specialized import *
from System.Windows.Forms import MessageBox
# Create an alias to the Autodesk.AutoCAD.ApplicationServices.Application class
import Autodesk.AutoCAD.ApplicationServices.Application as acapp
# Import references for Civil 3D
adoc = acapp.DocumentManager.MdiActiveDocument
ed = adoc.Editor
civdoc = CivilApplication.ActiveDocument
def point_to_point3d(pt):
return Point3d(pt.X, pt.Y, pt.Z)
def create_profile_view(align,loc,vn,bandset,style):
global adoc
global ed
global civdoc
result = []
# Get the active document in the AutoCAD session:
with adoc.LockDocument():
with adoc.Database as db:
# get alignment
alignId = align.InternalObjectId
#location
pos = point_to_point3d(loc)
#bandset
bandSetId = civdoc.Styles.ProfileViewBandSetStyles[bandset]
#style
styleId = civdoc.Styles.ProfileStyles[style]
for n in vn:
try:
# Creates a new profile view
profId = ProfileView.Create(alignId, pos, n, bandSetId, styleId)
except Exception() as ex:
MessageBox.Show(ex.message)
t.Commit()
for n in vn:
result.append(profId)
return result
alignment = IN[0]
position = IN[1]
names = IN[2]
bandsetName = IN[3]
StyleName = IN[4]
if not isinstance(names, list):
names = [names]
OUT = create_profile_view(alignment,position,names,bandsetName,StyleName)
Adding Band Sets to the above code I am getting problems, I have looked through api docs and I am confused as to how to get the id’s for Profile views Band Set styles, I thought maybe it was spacing in names so added underscores , but it appears I am referencing wrong styles!
import sys
import os
import math
ed = adoc.Editor
def create_profile_view(align, loc, vn, style, bandset1, bandset2, bandset3):
global adoc
global ed
global civdoc
result = []
# get alignment
# location
# bandset
bandSetId = civdoc.Styles.ProfileViewBandSetStyles[bandset1]
# bandset1
botbandSetId1 = civdoc.Styles.ProfileViewBandSetStyles[bandset2]
# bandset2
botbandSetId2 = civdoc.Styles.ProfileViewBandSetStyles[bandset3]
# style
styleId = civdoc.Styles.ProfileViewStyles[style]
for n in vn:
try:
botBandItems = profId.Bands.GetBottomBandItems()
botBandItems.Add(botbandSetId1)
botBandItems.Add(botbandSetId2)
profId.Bands.SetBottomBandItems(botBandItems)
t.Commit()
for n in vn:
return result
alignment = IN[0]
position = IN[1]
names = IN[2]
StyleName = IN[3]
bandsetName1 = IN[4]
bandsetName2 = IN[5]
bandsetName3 = IN[6]
names = [names]
create_profile_view(alignment, position, names, StyleName, bandsetName1, bandsetName2, bandsetName3)
