Am whiling to set Room shared parameter values, Am using “Element.SetParameterValuesByNames” Node, I lied all the inputs, as required, but when ran, I had error,
I have 750 space, 15 list of values (the same values get repeated each 15 space), and 6 parameters,
I need help please.
I lied the same script to “set parameter value” node, and it works, but when it comes to shared parameters, the only thing I could do is to assign them to elements, but can’t set their values
Thank you Gavin, Actually I didn’t follow exactly the script above because of some specifications, but the node from your package really made the difference and helped me to solve the situation,
Thank you !!
