Hi all
I have create a parametric mass family with some parameters and I am triying to change them in Dynamo…but it is impossible…I don´t know why it deletes some of the familys when i change the parameters in dynamo…I add the Dynamo file
ESTUDIO URBANO_EQUIPAMIENTOS HANOI.dyn (281.7 KB)
MASA_EQUIPAMIENTOS.rfa (448 KB)
I use revit 2017 and dynamo 1.1
As you can see in the parameter “Altura” is null the list…i don´t undestand why…
Thanks in advance¡
@JAVIER_FQG Make this crude alteration and see if it works…
tHX @Vikram_Subbaiah as allways helping me
I gonna try and i will write…u reccomend me that when i want to change multiple parameters in a family do it this way or is just to try something different?
Thnak u so much, I will write soon with the test result¡
If you look at other discussions on the forum you will find efficient alternatives to repeating the Set Parameter node while assigning multiple parameters.
However in this case of yours, I suspect you’ll need to change parameters in sequence. Not sure, so just want you to try.
