After creating viewsheet i would to set parameter of drawn by and checked by with python script but i can’t find a good code.
Hi, as Nick mentioned, you should use the Set method.
Here’s a basic “Set parameters” script as example :
clr.AddReference('RevitAPI')
clr.AddReference('System')
element = UnwrapElement(IN[0])
param = IN[1]
values = IN[2]
done=[]
notDone=[]
for e,vList in zip(element,values):
flag = False
for p,v in zip(param,vList):
elem_param = e.LookupParameter(p)
if v == None or v == "":
flag = True
if not elem_param.IsReadOnly:
elem_param.Set(v)
flag = True
if flag:
notDone.append(e)
done.append(e)
OUT = done,notDone
It works, I just discovered drawn by and checked by for viewsheet don’t need the buitInParameter to set value and the LookupParameter method is enought.
Regards
