My excel has a column for house numbers,its corresponding post code and house id. I’m trying to compare those values from the values fetched from revit parameter named ‘house number’ and ‘pincode’. I want to set the corresponding house id from Excel to the room in Revit where house number and pincode is equal to the combination of values of columns in Excel. Have attached the Excel and the code.
clr.AddReference(“RevitAPI”)
clr.AddReference(‘RevitNodes’)
doc=DocumentManager.Instance.CurrentDBDocument
#rooms=IN[0]
collector = FilteredElementCollector(doc)
rooms = collector.OfCategory(BuiltInCategory.OST_Rooms).ToElements()
List of list of coloumns “House Number”,“Zip code”,“Bag ID”
room_housenumberExcel=IN[1]
room_housenumber=
room_PostcodeExcel=IN[2]
room_Postcode=
room_bagidExcel=IN[3]
room_bagid=
output=
for room in rooms:
for param in room.Parameters:
if param.IsShared and param.Definition.Name == ‘Huisnummer’:
room_housenumber.append(room.get_Parameter(param.GUID).AsString())
if param.IsShared and param.Definition.Name == ‘Vabi_BAGpandID’:
room_bagid.append(room.get_Parameter(param.GUID).AsString())
param_BagPandId=room.get_Parameter(param.GUID).AsString()
for j in range(len(room_housenumber)):
for k in range(len(room_housenumberExcel)):
if (room_housenumber[j]==room_housenumberExcel[k]) and (room_Postcode[j]==room_PostcodeExcel[k]):
param_BagPandId.Set(room_bagidExcel[k])
OUT=output
