Set multiple parameters value to multiple elements
Hi
Need help with setting multiple parameter values imported from excel to multiple element. It works when I select one index of parameters and its value but when I want to set multiple values it doesn’t work.
Please help.
Check to make sure all of your lists have the same format and count. I don’t see what you Values look, but check Levels and Lacing.
