Set material to a new wall type
Hi All, @c.poupin
By using Revit Python Shell (a similar approach to Dynamo), I’ve written the code below to iterate over all materials within the document. I grabbed the material named Béton, coulé sur place with the ID 183853, which I’m trying to use as a layer material in my new wall type. However, I’m encountering the following error related to the MaterialId."
Exception : Microsoft.Scripting.ArgumentTypeException: expected Reference, got Int32
import math
from System.Collections.Generic import IList, List
uidoc = __revit__.ActiveUIDocument
doc = uidoc.Document
t = Transaction(doc, 'create New wall type')
# getting the first wall type within the document
first_wall_type = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsElementType().FirstElement()
# looking for the material named "Béton, coulé sur place " in the document
mat_Ids = FilteredElementCollector(doc).OfClass(Material).ToElementIds()
for m in mat_Ids:
    mat = doc.GetElement(m)
    if mat.Name == "Béton, coulé sur place":
        mid = m
c = 1/0.3048
# Starting transaction
t.Start()
voile_BA_15 = first_wall_type.Duplicate('voile-BA_15')
cs = voile_BA_15.GetCompoundStructure()
Thick_wall = 0.20*c
mat = doc.GetElement(mid)
cl = CompoundStructureLayer()
cl.Width = Thick_wall
cl.MaterialId = mat.Id
cs.SetLayeres.LIST[CompoundStructureLayer](cl)
voile_BA_15.SetCompoundStructure(cs)
t.Commit()
Any help would be appreciated
Thanks.
here an example
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import specify namespace
#import net library
from System import Array
from System.Collections.Generic import List, IList, Dictionary
clr.ImportExtensions(Revit.GeometryReferences)
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
clr.AddReference("System.Core")
clr.ImportExtensions(System.Linq)
first_wall_type = FilteredElementCollector(doc)\
							.OfCategory(BuiltInCategory.OST_Walls)\
							.WhereElementIsElementType()\
							.First(lambda x : x.GetCompoundStructure() is not None and x.GetCompoundStructure().GetLayers().Count == 1)
mat = FilteredElementCollector(doc).OfClass(Material).First(lambda x : x.Name == "Béton, coulé sur place")
c = 1/0.3048
if True:
	t.Start()
	Thick_wall = 0.20*c
	for structLayer in cs.GetLayers():
		cs.SetMaterialId(structLayer.LayerId, mat.Id)
		structLayer.Width = Thick_wall
	t.Commit()
OUT = voile_BA_15
Hi @c.poupin
I tested your script, but I got the following error, related to the line below:
lvl
However, I tested the same code in the Revit Python Shell, where I was able to access the level properties, but I received the following error in the RPS console related to this part of the code:
Exception : System.MissingMemberException: ‘NoneType’ object has no attribute ‘GetLayers’
Thanks.
Probably, the type you are duplicating has no CompoundStructure Layers, please look at all of my code
@c.poupin
Effectively, after debugging the code I discovered that the first_wall_type is a curtain wall, which does not seem to have a CompoundStructureLayer . In this case, I need to apply a filter that selects only the Basic Wall kind, but I’m struggling with how to do that.
I tried this syntax for the filter, but it doesn’t work!
filter = ElementCategoryFilter(BuiltInCategory.OST_Walls)
First_wall_types = FilteredElementCollector(doc).WherePasses(filter).WhereElementIsElementType().First(lambda x : x.Kind == WallKind.Basic)
I’m getting this error:
Exception : System.MissingMemberException: ‘FilteredElementCollector’ object has no attribute ‘First’
Thanks.
for this example I use LINQ with Ironpython3, but you can replace by another type of filter (Predicate.Find, list comprenhesion, next(iterable), etc…)
https://daren-thomas.gitbooks.io/scripting-autodesk-revit-with-revitpythonshell/content/using_linq_in_ironpython/
Hi @c.poupin
It’s hard for me to use this filtering method at the moment. However, I solved my issue another way, and finally, I got my code working and tested it by creating walls as shown in the image below:
Here the Final code (using RPS):
import math
t = Transaction(doc, 'create Manhole')
wall_types = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsElementType().ToElements()
levels = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Levels).ToElements()
types = []
for w in wall_types:
	if str(getattr(w, 'Kind')) == 'Basic':
		types.append(w)
for m in mat_Ids:
        mid = m
for l in levels:
    lvl_Name = l.Name
    if lvl_Name == "Niveau 0":
        lvl_Id = l.Id
# Create Points and Lines:
c = 1/0.3048
Thick_wall = 0.20
Pt0 = XYZ(-(0.60 + Thick_wall/2)*c,-(0.60 + Thick_wall/2)*c,0)
Pt1 = XYZ((0.60 + Thick_wall/2)*c,-(0.60 + Thick_wall/2)*c,0)
Pt2 = XYZ((0.60 + Thick_wall/2)*c, (0.60 + Thick_wall/2)*c,0)
Pt3 = XYZ(-(0.60 + Thick_wall/2)*c,(0.60 + Thick_wall/2)*c,0)
Lines = []
Line1 = Line.CreateBound(Pt0, Pt1)
Lines.append(Line1)
Line2 = Line.CreateBound(Pt1, Pt2)
Lines.append(Line2)
Line3 = Line.CreateBound(Pt2, Pt3)
Lines.append(Line3)
Line4 = Line.CreateBound(Pt3, Pt0)
Lines.append(Line4)
t.Start()
# Create new wall type and its material:
voile_BA_15 = types[0].Duplicate('voile-BA_15')
	cs.SetLayerFunction(structLayer.LayerId, MaterialFunctionAssignment.Structure)
	cs.SetMaterialId(structLayer.LayerId, mid)
	structLayer.Width = Thick_wall*c
# Create walls:
for l in Lines:
    Wall = Wall.Create(doc, l, voile_BA_15.Id, lvl_Id, c*2.00,0.00, False, True)
t.Commit()
Thanks a lot Cyril.
