It works great and adds all the parameters that i want, the only thing is that a few parameters should be Instance Reporting parameters and therefore Read Only in Revit.
Is there a way to set my instance parameter to read only? I found the way to check if they are read only, but no way to set them read only
i already downloaded our Orchid package and i will use them from now on instead of the DanEDU.
If i find any problems or things that worked in the old one then i will give feedback to you of course.
Thanks a lot for considering this in you new nodes, this is really a thing that saves me a lot of time
I tried a few of your notes that I need and they work perfectly with the βolderβ 1.3.2 Dynamo version.
Also including the Reporting Parameter function, thank you a lot for that.
