Set Drop-Down Parameter for Tag
Hi everyone,
I need to change Electrical Fixture Tag parameter from “Attached End” to “Free End”.
The topic has been explored many times and still basic operation with straight-forward nodes yield only “The parameter’s storage type is not a string”. Maybe someone with a fresh pair of eye would not mind to share the solution?
Sorry for bothering.
What do you get if you return the parameter value instead of the parameter name? The parameter is a checkbox so it’s likely a boolean.
EDIT: You should also be looking at the Leader Line parameter, not Leader Type.
That is exactly what happened! Thank you so much!
