Hello !!
I am trying to set a crop region by curves, and am trying both with curves and bounding box, but non of them are working, and it’s not giving any warning, so I don’t know what I am doing wrong.
Any idea?
Maybe you can show us your method - how are you trying to set it?
One possibility is that you set the cropBox correctly but you don’t make it active.
I don’t have at the moment solution for curves (can try later) - but this works for a bounding box:
from Revit.Elements import *
view = UnwrapElement(IN[0])
bb = UnwrapElement(IN[1])
view.CropBox = bb.ToRevitType()
view.CropBoxActive = True
OUT = 0
For the bounding box part - I think the node is expecting a bb list and you give a single bb.
As for the byCurves path - have you tried inputing a list of curves instead of a polycurve? The node might also be expecting a list of lists (of curves). One curve list for one view.
Do you want to set the same cropBox for all the inputted views by the way?
No, I didn’t try with list, so I will work on it.
For now, I am trying to set for all views, but then I will change it to Current Selection with boolean.
Thank you a lot.
Take a look at this link and see if it can help. I think the MEPOver package may have nodes to help.
Thank you SeanP.
Now, I am very close to a solution, but have one problem.
I can not understand why, but this script is working for only one view and no for any other.
When I am trying to select another view, it’s not working.
And it’s totally not working when I am selecting several views.
Maybe I have to try without boolean.
@TomArchitect
The View.GetCropBoxCurves works only for ONE View unlike the View.SetCropBoxCurves (which works for multiple Views).
I ran into similar (a) problem(s).
I am looking for a solution to get the Crop Regions from MULTIPLE Views.
