I would like to set the Truss members, in this instance the Top Chord, using the Builtin parameter. I am using the Archi-lab node.
Any help, much appreciated.
You are inputting a Framing Type to the Parameter Values. This input looks like it needs a parameter, not a framing type.
Are there any other errors you are getting?
Thanks @Tom_Kunsman I checked further after your hint.
Used another archi-lab node Parameter.SetBuiltInParameter which needs an Id as value.
It works now.
