Yna_Db is correct, it’s read only and you need to use the SetProjection Method in a python node.
Here is an example of how to use the method:
element.SetProjection(AnalyticalElementSelector.EndOrTop, StickElementProjectionY.LocationLine, StickElementProjectionZ.Bottom)
Here is a complete working code:
# Import Revit API
# Input
elements = UnwrapElement(IN[0])
if not isinstance(IN[0], list):
elements = [elements]
#Make changes to Revit DB in a Transaction
for element in elements:
OUT = 0
