Set Analytical Floor Alignment
Hi
Anyone knows how I can set the Analytical floor Alignment “z Projection” to “Top of Element” or “Bottom of Element” through Dynamo? I get an error when typing a string.
If it is a dropdown option you have to use a number. most likely a pattern like this
Option 1 - 0
Option 2 - 1
Option 3 - 2
Option 4 - 4
Option 5 - 8
You can figure it out by using Element.getParameterValueByName
@Ahejnfelt You might find this useful…
I have tried using numbers instead, but when I use “Element.GetParameterValueByName” it returns a string:
Yes that is strange, it looks like it’s expectiing a ElementId as input, here is a screenshot from Revit Lookup:
I’m not sure how to get the ElementId of the top surface of your floor, but if you feed it a level it will work:
I took another look at this, but had to turn to python to make it work:
(Edit: Python is updated, center and bottom had swapped places)
clr.AddReference('RevitAPI')
#Functions for list handling
def ProcessList(_func, _list):
    return map( lambda x: ProcessList(_func, x) if type(x)==list else _func(x), _list )
if isinstance(IN[0], list):
	analyticalFloor = ProcessList(UnwrapElement, IN[0])
	analyticalFloor = []
	analyticalFloor.append(UnwrapElement(IN[0]))
#Create a dictionary for getting the correct enum
prjOptEnum = {
"Top of Element" : SurfaceElementProjectionZ.TopOrInterior,
"Bottom of Element" : SurfaceElementProjectionZ.BottomOrExterior,
"Center of Element" : SurfaceElementProjectionZ.CenterOfElement,
#Look uo the the enum
projOption = prjOptEnum[IN[1]]
#Define function for API method:
def setProjection(aFloor,pOption = projOption):
		aFloor.ProjectionZ=pOption
#Change projection method in a transaction
ProcessList(setProjection,analyticalFloor)
OUT = analyticalFloor
Hi Einar
Thanks a lot for the help!!
