Set All layout Page Setups to a Named Page Setup
Greetings,
I am trying to set all layout page setups in the current document / dwg to a named page setup that is available in the current document.
I have found Camber nodes to get the layout names, and get the named page setups available, and even found one that will create a new layout with an available page setup.
The Camber Layout.ByName node is able to change the pageSetupName of and existing named layout, I am just not sure how to feed it a list of all of the layouts in the dwg, if that is possible.
Thank you,
Boris
Correction: Camber “Layout.ByName” node does not seem to be made to work with an existing Layout, and gives a “Warning a layout with the same name already exists”.
