Sequence error
Hi all,
I am started learning dynamo. the 1st attached image is taken from the Dynamo primer wire topics.
But I couldn’t get the same results when I try with the Revit dynamo.
Please guide me on this. I attached my Working Resultant.
Check the lacing on the Point.ByCoordinates node. You’re in shortest, the primer is using cross product.
Also it appears you are likely missing a Dynamo update in whatever version you’re using. 2.0.4 is the latest for Dynamo for Revit 2018 and 2019, which provides Auto lacing as the default.
let me check my version and retry
Thank you
