Hola. Queria consultar si es posible crear un scrip para seleccionar familias de un modelo vinculado dentro de un proyecto. como apenas estoy empezando en dynamo. no se por donde iniciar.
Edit for Translation:
Hello. I wanted to see if it was possible to create a scrip to select families from a linked model within a project. I’m just starting out at Dynamo. I don’t know where to start.
Hi
The forum language is English… Please use a translator otherwise we will not be able to help you…
KR,
Patrick
Yes. Please make all post and replies in English or with a translation as it’s needed for proper search functionality. Also, do not make duplicate posts (I went ahead and deleted your first). You can modify or edit an existing post if you need to.
I would also suggest you look at the forum rules and the below topic for requesting help. You need to show some effort first before asking for anything. Try searching for similar topics and see what you find.
How to get help on the Dynamo forums - FAQ - Dynamo (dynamobim.com)
