Selecting specific surface for profile view
Hello!!
I have a profile that shows the terrain surface and the projected profile. I need to select the projected profile. How do I do this on Dynamo?
exemplo perfil
I used the nodes below to try to select the profile, but it doesn’t select the projected profile. Any idea?
exemplo nó
Hi @dffreitas,
You should be able to just select the Profile directly. Or you can select the parent Alignment and then use the Alignment.Profiles node.
Actually, I need to extract some information from this profile, like Maximum and Minimum Elevations, Starting and Ending Stakes.
exemplo nó 2
If I use the “Alignment.Profile” node, I can’t get the information I need.
I guess maybe we should clarify terms. Are you trying to get information from a Profile View or a Profile?
From a profile.
I want to read the information on Maximum and Minimum Elevations, and Starting and Ending Stakes.
exemplo perfil
I was trying to read this information from Profile View, but I wasn’t selecting just the projected profile.
Would this work?
Thank you so much, @zachri.jensen
