I just wrote a script that worked well for one object. I set it up for Dynamo Player, exited Dynamo and used the Player four times. One of the times I didn’t get the result I expected, so clicked on View Graph in Dynamo to see what’s up. Ever since then, I can’t select an object. The four character object code changes if I select something different, but the output is always null. Even if I go the other route of selecting all by type, or selecting all on layer. Null. Restarted computer, closed C3D and come back, created a new drawing. Null. Tried a different script. Null. Change to Select Objects node. Shows two object codes, but…Null output.
Any tips?
