Selected Objects output
Hi All,
Following on topic here Select Multiple Anyone know how to return out as MapFeature(to be specific) Object by handle is not working if i select map feature.
if the output is string
@myrwen.junterealSJC7 the MapFeature in the Toolkit is a class that is not derived from a Dynamo AutoCAD or Civil Object and it will not work with ObjectByHandle.
Thanks Paolo
@Paolo_Emilio_Serra1 Using the ObjectByHandle with an AutoCAD 2D polyline (Spline) gives me the same error.
