I`ve a question about the select surface node. When I select a surface with multiple voids like in the attached image dynamo makes a list where 1 void is considered a subsurface and the others are merged into one single surface. What I want is to translate the voids to geometry in dynamo so I can use them to cut geometry that I make with dynamo and place on the surface. is there a way to consequently select the voids in a Revit surface with dynamo?
Wouter
