Hi, how can I select the plates that are part of the connection to set them the general parameters of the instance through the Dynamo. Dynamo can select them if only the connection is disassembled or the plate is created separately. How can I select them without disassembling the connection? Revit 2021 Dynamo 2.5
Related topics
| Weld seams, steel plates of structural connections | 0 | 37 | October 27, 2025 | |
| How to select an element within a connection / profile | 2 | 191 | February 24, 2023 | |
| Unable to select the Dynamo output in Revit | 2 | 849 | March 28, 2017 | |
| How get set sub element of steel connection parameter value | 1 | 45 | November 7, 2025 | |
| Finding out if two steel parts are in-shop connected | 3 | 219 | March 9, 2024 |
