Connection Parameter
Hello all,
I have been looking for a way to use the tab select functionality from Revit in dynamo, maybe using it to create a set. However, after a bit of research it looks like that is not possible. So now I am wondering if there are any parameters that duct or pipe systems might have that specify if it is connected to another element or not. Revit must have some way of determining this as it seems needed for the check systems functionality. Does some sort of parameter or check for connectivity exist, and if so can it be accessed from dynamo?
Thank you in advance!
Just post some screenshot, do you have some script?
First idea is sort your elements by system. you can see at least if there are a disconnection.
KR
Andreas
@Carter123 try DynaMEP package:
Hello @Carter123 ,
It depend upon excepted outcome, like whether you wanted to select elements connect with your selected element, Use DynaMEP package as @Elie.Trad mention
If you wanted to select completed network which is connected with your selected element then use MEPover package, as I have mention,
Hope you got the answer what you are looking for
GroupByKey could work.
KR
Andreas
