Is there a way of selecting the sheets category without the need for the Categories node with drop down list?
We have a script thats setup specifically for sheets but the categories node seems to ‘reset’ itself between Revit version. From what I read this might be because new categories are added from one Revit version to another but I haven’t come across a solution.
Someone mentioned using a Object Styles Type (I think), I tried OST_Walls in a cade block without luck, should it be something else specific?
I also remember a node that has all categories as output but I can’t find it or remember the name, an OOTB solution would be preferred though.
