Thanks in advance,
Anyone know how to select lines in a DWG file imported into Revit AutoCAD layers? I have tried using the parameter line style to differentiate all the lines and group but only tells me they are model lines.
Thank you very much!
Thanks in advance,
Plug in the All Elements Of Category into Element.Name and it will give you the name of the line.
Thanks for your answer Martin
But I would be interested in selecting lines for each layer Autocad .
The name of the layer is then placed in the parameter line style , so if you could select from this " line style " parameter line model could select lines per layer CAD
Yes! Is perfect! thank you very much for your help Vikram!
