Select Elements by category on Subform
I can pickobjecks by category in one Form, but when try get it on Form2 (Subform of Mainform)
Revit is Freeze.
Please explain it.
Thank Advance!
#Get in 1 form, run in Ironpython2
import clr, System
clr.AddReference('RevitAPI')
from Autodesk.Revit.UI.Selection import ISelectionFilter
class Single_Category(ISelectionFilter):
    def __init__(self, cat):
        self.cat = cat
    def AllowElement(self, e):
        if e.Category.Name == self.cat:
            return True
            return False
    def AllowReference(self, ref, point):
        return true
def selects():
    elements = []
    try:
        pickeds = uidoc.Selection.PickObjects(Selection.ObjectType.Element, Single_Category("Lines"),"Let's select Lines then press Finish")
        elements = [doc.GetElement(i) for i in pickeds]
    except:
        pass
    return elements
clr.AddReference('System.Windows.Forms')
clr.AddReference('System.Drawing')
import System.Drawing
import System.Windows.Forms
from System.Drawing import *
from System.Windows.Forms import *
class MainForm(Form):
    def __init__(self):
        self.InitializeComponent()
    def InitializeComponent(self):
        self._button1 = Button()
        self._button2 = Button()
        self.SuspendLayout()
        # button1##
        self._button1.Location = System.Drawing.Point(160, 230)
        self._button1.Name = "button1"
        self._button1.Size = System.Drawing.Size(70, 25)
        self._button1.TabIndex = 0
        self._button1.Text = "Cancel"
        self._button1.Click += self.Button1Click
        # button2
        self._button2.Location = System.Drawing.Point(260, 230)
        self._button2.Name = "button2"
        self._button2.Size = System.Drawing.Size(75, 25)
        self._button2.TabIndex = 0
        self._button2.Text = "Select Line"
        self._button2.Click += self.Button2Click
        # MainForm
        self.ClientSize = System.Drawing.Size(360, 270)
        self.Controls.Add(self._button1)
        self.Controls.Add(self._button2)
        self.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedSingle
        self.MaximizeBox = False
        self.MinimizeBox = False
        self.ShowIcon = False
        self.StartPosition = System.Windows.Forms.FormStartPosition.CenterScreen
        self.Name = "MainForm"
        self.Text = "Select line"
        self.ResumeLayout(False)
        self.PerformLayout()
    def Button2Click(self, sender, e):
        self.element = selects()
        self.Close()
    def Button1Click(self, sender, e):
        self.Close()
form = MainForm()
Application.Run(form)
OUT = form.element
#This is tried get Lines in SubForm
#Get in subform, run in Ironpython2
import clr, System
        self.cat = cat
            return True
            return False
        return true
def selects():
    elements = []
    try:
    except:
        pass
    return elements
class SubForm(Form):
    def __init__(self):
        # button1##
        # button2
        # MainForm
        self.Name = "SUbForm"
        self.Close()
        self.Close()
#Mainform
    def __init__(self):
        # button1##
        # button2
        self._button2.Text = "OpenForm2"
        # MainForm
        self.Text = "Task 1"
        self.subform = SubForm()
        self.subform.ShowDialog()
        self.Close()
form = MainForm()
OUT = form.subform.element
Application.Run(Form) starts a message loop on the current thread and displays the specified form. The message loop enables the form to allow it to appear responsive and have interaction with the user.
When you call ShowDialog() a modal message loop for the form is created and block the thread
try to replace
by
self.subform.Show()
Thank you so much!!!
I realize must not Close MainForm when active event SubForm.Show() to get subform.element
